◌◌◌Kicker WARHORSE◌◌◌
bumpin buick
Science is everything
Kicker Warhorse
Used for three shows in LNIB condition. I have original box with all original pieces as well.
4 ohms: 5,000 watts x 1 chan.
2 ohms: 10,000 watts x 1 chan.
$1250 shipped in the US
Max power output: 20,000 watts x 1 chan.
Signal Modulated power supply allows for ultra-high-efficiency
Wired remote bass level control included
Unique power supply allows for amplifier to output 10,000 watts with 90% efficiency
8 green LED indicators display the status of the amplifiers protective circuitry and assists in troubleshooting
Variable Bass Boost (0 to +18 dB bass boost at 40 Hz)
Preamp RCA outputs to daisy chain multiple amps
Separate voice coil wiring terminals allows for user to hook up each subwoofer voice coil to dedicated terminal
High-density split-dome convection heat sink for extreme heat dissipation
Gold-plated RCA level inputs
Gold-plated screw terminals
Input sensitivity:
Low level: 170mV-5V
Variable low-pass filter (50-200 Hz, 24 dB/octave)
High Pass Subsonic filter (20-60 Hz, 24 dB/octave)
CEA-2006 compliant amplifier
Frequency response: 20-200 Hz
Dimensions: 35"L x 17-3/4"W x 3-3/4"H
Minimum Power Requirements: Eight 12-volt Batteries, and two 200-Ampere Alternators. For more information regarding the Warhorse Power Requirements, please read the User Manual
Triple 1/0-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier
Got a birth sheet? And can we get a pic with username?
Im sure people will vouch for me I have had a few hundred deals on here. I can get a pic later but I have sold many high dollar items on here. Maybe a few hundred Stinger batteries as well.
bumpin buick
bumpin buick
Appleton, Wisconsin
jj4475
    May 16, 2024
    May 16, 2024
