99 Camry post install help
  • 3
Not sure if this is the best forum to ask considering im looking for advice and tips. I recently ate a pole in my sienna and i am about to buy a 99 Camry le. I will be putting my old system in there and heard there are holes in the firewall but probably won't take my 0gauge. So I plan to run that through the fender. And my sub's are sealed so if I remove the rear deck speakers will I have more bass in the cabin.
If anybody has ever had a system in these cars I would really appreciate any advice and help you can share.
Run it through the fender? Really?
Any size wire can be ran through the firewall. There is probably a clutch plate on a 99 Camry. It doesn't get any easier than that. Or you just drill a hole next to the factory grommet.
2001 Toyota Camry Car Audio Install
Pretty old build but this is most of what I did with my '01. I believe it's the same body style.
definitely remove rear speakers. You will shred them if you run subs.
VERY hard to get loud out of that trunk though and the angle of it makes it difficult to fit in a box much larger than 7-8 cube gross.
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times...
bullheadaudio
Greene County, NC
hispls
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
