replaced Camry Entune with Alpine INE W970
  • 2
retiredat44@hotmail.
CarAudio.com Newbie
4
Oregon
2014.5 Camry Hybrid. replaced Entune with Alpine INE W870. Radio reception is terrible! Professional installed. (due to my age and health I don't do work anymore). I am really bummed, well both my wife and I with this. The GPS is great, great HeadUnit. But only way to use radio is by using iHeart! I have searched al over and asked people. No good answers! help! Thanx!
I am going to have to pull it out of the dash and have a look again to see if the wires are correct. I sent over this with a pro shop many times during several days of an install. They never touched the amp in the rear window pillar where the antenna amp is. Online is no help. I searched Youtube, and really haven't found much. The antenna and reception was fine with the Entune, but the GPS ******. The GPS works great in the alpine, but now the am/fm reception *****. guess the word ***** can't be used here I guess??????, just say it is really really really bad!
JUST BRAINSTORMING HERE: Yeah, you might also want to compare the backs of both. (You just said "android radio", is this an amazon special...
13
Super easy and Cheap..Ill bet your father or Gramps can solder it pretty easily?? You Tube is your friend too. As well as H.freight /Lowes/or...
14
Is that speaker in the existing rear deck? Are you running a sub in the trunk?Do you have that speaker on an amplifier?Are you using a stock HU...
5
Before you remove the amp, swap the front RCAs with the rear ones on the amp and repeat the test. Many guys here use the Pioneer amps and love...
If your bypassing the infotainment stuff in the original HU setup, then the LCi7PRO should handle the rest. If you want to retain the handsfree...
CarAudio.com Newbie
Oregon
SlugButter
    May 4, 2024
slater
    May 2, 2024
Latest topics
