99 Mustang GT Build
Mike465
Ami Creations
2,858
Kennesaw, GA
Ok everyone this build is for a local guy's 99 Mustang GT.
I will be building out the entire trunk on this one .
Equipment
Two 12" DB Drive K5F shallow mount subs
One DB Drive A5 1200.1D for the subs
One DB Drive A5 125.4 for all the mids and highs (Not sure what they are)
I will be building a new floor, amp rack, box, re-wrapping the trunk liner and trimming the trunk off.
Here's the car............................................... ..............
Starting to wire the trunk for the amps............................
After doing some wire management.....................................
Ground Distribution Block........................................
Power Distribution Block...........................................
Trunk liners put back in...........................................
New floor cut out............................................... ................
Making room for the amps to be flushed in the floor.............................
Brace to hold the amps in place................................................
A little test fit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif .................................................. ..........
Getting started on the box............................................... ........
As you can see the car has a convertible top so space is very limited
Test fit time //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif .................................................. ........
Box trimmed off.............................................................
Trunk liner re-wrapped.............................................
Box trim panels wrapped..................................................
LOL, I kind of like them. Thw tag says "NOWUDNT"
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
I spoke too soon to see the last picture post. Very nice work trimming everything off. Isn't sealing off the trunk like that worse for sound purposes though?
you do great work mike. the car needs new shoes and a paintjob but there's nothing you can do about that //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Might not even be an issue if you don't have any really big panels on it. Otherwise dowels or threaded rod across your wide panels would be the...
18
3K
I ordered the car with the upgraded B&O audio system....turn's out Ford bought the name but they didn't buy the quality. The system ****** to me...
Contact ANS he has a used Focal 8 Channel DSP that went for 1,300 bucks and is selling used I think shipped for 450. And from what I have seen and...
13
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
Mike465
Ami Creations
Mike465
Kennesaw, GA
bigbangtheory
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
