A/C Question?
  • 2
GRANDV
I had a new A/C condensor fan and motor installed in my Grand Vitara. It was checked by the mechanic that it was not leaking freon. So, picked it up and notice on the 3rd day after that the a/c was not working. So, before I went back, I replaced the fuse and still nothing. They check it again and said that they replaced the freon and bam it was working. Then after a week of not using it and then on Saturday, turned it on and hot air again. Does anybody know if there might be something else going on. I wanted to know before I took it back and had them check it again for the 3rd time. Thank you.
What it sounds like to me is that all of the refrigerant is leaking out. When you get below a certain level of refrigerant, (usually a little under a pound) the a/c wont work. What happens is that it notices that you are low on refrigerant and it doesnt let the compressor kick on. If I were you I would check to see if the compressor is engaging. If it isnt and they add refrigerant to it and it works then that means that you have a leak. If you go there again and they add refrigerant and it works and they send you on your way and it quits again, I would go somewhere else and have it checked out.
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
530
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
821
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
7
580
GRANDV
GRANDV
Ramsey, MN
Russ Raymer
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
