A car audio tech recommended for me to get my system rewired. Am I getting scammed? Or should I go for it?
Just the power and ground being that exposed is dangerous enough in itself to need fixing...I'd say he's been fairly lucky so far...
How do you figure? Just installing head, running an amp, and replacing 4 stock speakers is a half a day job and 125 an hour for garage time seems about right. Consider whoever touches this needs do all of that plus pull everything that has been done to confirm there's no other issues and when OP drives away they're going to be come liable for anything that happens.
If you're going to quote what I say, and respond to it, how about you at least quote the entire sentence.
I really do not know what everyone here is going on about this "dangerous" install. The red/black wires are for the 6.5s. Each wire is twisted and taped individually with electrical tape. The blue/black wires go to the sub and are also twisted and taped individually.
That amp obviously goes tucked under the driver's seat but was pulled out for the photo. Like I stated earlier, the only issue I see is the exposed power cables. Add to this the OP's statement that all was working fine and dandy until the Polk tweeter's install.
So you think the exposed power cables on an unsecured amp are not dangerous?
You don't know if the amp is "obviously tucked under the seat". That's just your assumption at this point, and it's almost irrelevant, but it isn't, that would make it worse. If that were true, then it means the wires that go under the carpet, would definitely be right under the feet of anyone in the back seat.
"Add to this the OP's statement that all was working fine and dandy until the Polk tweeter's install."
And the best of their knowledge involves having someone else do what's pictured in their vehicle, and then needing to ask not only an installer if it's cool, but posting it on here to see what feedback we can provide.
IMO it's more of a "we don't know" but judging by what we can see from the picture it's not unreasonable to expect that there's no fuse, no grommet where he came through the firewall (if he didn't just pinch it up through the hood and through the door or some other ghetto ****) or whatever all else may have been done dangerous or half arsed.
It doesn't look like OP is coming back. He probably is doing 30 days in county for beating the **** out of his "friend" who did this.
On your response to hispls you quoted lack of context usage. Now you do the same to my post. I said "except the bare power cables".
Yes, it is just an assumption, but, how many amps have you seen just laying in the rear passenger footwell? I have never seen one. How many have you seen tucked under the front seats? So it is an assumption relying on hindsight.
I guess there could be a danger in that but most wire is routed under the door sills. Carpet also has the jute padding that would protect against hard abrasions or impacts so there is that.
Well, yeah. All OP knows is all was working right, then after installing the tweeters he started having issues. His buddy could not make sense of it either hence him going to pro shops and ultimately here.
Because it is a dangerous install, The damn amp is not even mounted for one, with half the power and ground frayed and sticking out of the inputs.. You see no danger in this?
If the installer friend half assed these simple steps I wouldn't count on this being a safe install period.
Seeing as installer was able to make sense of the wiring harness, I give him the benefit of the doubt that he knows a main fuse within 18 inches of the battery is standard practice. As for the use of a gromnet, I do see your point in that.
This is the one thing I did highlight. I see many amplifiers not mounted to their base. They are just sitting in the trunk, under the front seats, or under the bench seats. I explain the danger of the amp flying in an accident but most just shrug it off. I too have my full range amp unmounted. Just laziness on my part.
No, I read and quoted all of you, and responded to the part that mattered. I didn't leave any out to pick out a response, I responded to one part of it, there's a difference. You can't even see what those other wires are doing, and I didn't even bother with how "wrapped in electrical tape, is good enough".
As far as how many amps are just laying in the footwell, I see this one. OP didn't say it's tucked under the seat, nor did they show it that way. It's not hindsight, and you shouldn't base this install on what you know. It's BASED ON WHAT WE CAN SEE, why are you assuming anything else is done right? My first install when I was 16 was better than this, and that was before youtube. We don't know where those wires are going, and WHY ARE THERE 6 OF THEM? WHY are there 3 power and 3 ground that aren't even part of the sub amp?
Right that's all op knows, (not trying to bash OP right now). Tell me, do you know where that ground cable is going? Do you know if it's got a good ground, or ran back to the battery? Do you really think the rest of the install was done properly? The only thing I'm assuming is that based off this 1.3 out of 10, I'm going to guess the rest was done as bad.
For me, the dangerous part is the combination of the amount of exposed wire, and the lack of securely mounting it. It could shift the amp, shift the cables, and cause an arc.
You must have missed when I prefaced with "Only issue I see is those bare power cables". It is in my original response to OP.
Lol, I see your point. Let me then ask you; why would you assume the amp was not tucked under the seat before the picture was taken?
FYI, economy electrical tape is rated up to 600v.
Of course it is hindsight. Almost everything that everyone does is based in hindsight. Hindsight and experience walk hand in hand. Do you think OPs installer knew how to connect that amp out the chute? No, someone taught him. Seeing someone do it and applying logic is what made him the professional amp installing god he is today. The reason I assume everything else was done right is because OP told us all was working fine.
Well, we could use hindsight.
If OP asked for your help to install an amplifier because his old one was stolen; all you had to go by was those wires in the picture. Would you be able to figure out the wiring at a glance? Also, it is a 5 channel amp.
No, no, and no.
Yes. OP said all was working good. After the tweeter's install he could not go above "half" volume before it started cutting off. This tells me he could go almost full volume before with no issues.
I would agree with you here but I bet the speaker wiring guide is not printed on the amplifier. That means installer read the manual for guidance. Every amp install manual prefaces with safety practice. That is disconnect battery and install a main fuse near the battery
I concur.
IDK, man, I've seen some absolutely bizarre stuff in my time. Enough telltale signs of novice install here to expect anything and everything to be done wrong.
Fair, and I have done the same in some situations, but would never leave a situation like that in someone else's vehicle.
Also consider the shops he took this to may have seen more and worse elsewhere, hence the 800$ price tag on the fix and their insistence that it is dangerous.
Agreed, this is the most glaring issue. But again, if something is left looking like that what else is going on, and what did these shops see in addition to what we are shown?
I doubt it. More likely the guy did this just watched some other muff who didn't know what they are doing install a few and figured he knew what to do.
TBH, I have never seen an amp install without the main fuse by the battery. But then again...
I just looked up the amp and it does have the pinout printed on the amp. The installer used blue/black and red/black as front channels, then used the other red/black as sub channel. I would have used blue/black as sub channel for easy identification.
My main point is that using electrical tape for an install is common practice and not a danger to where one would need to rip it all out to redo it "professionally". As for the bare power cables, that happens when the amp moves around. You could wire it in nice and snug with no skin showing but when you move the amp around it will push the sheath back even if you use ferrules.
We have been in this hobby long enough to know that alot of shops prey on those who do not know the hobby. My guess is they saw an easy target and gave him the scorched earth spiel.
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
517
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
400
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
916
Does you car have the noise cancelling mics from the factory? Usually right above the drivers door. If so, snip the wire to one of the mics to...
13
609
Og_slim2
CarAudio.com Newbie
Og_slim2
Orlando
1aespinoza
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
