Accidentally shorted door speaker wires, now getting interference šŸ˜”
  • 2
na96ek
32
TN
To make a long story short, Iā€™ve had my current setup running untouched for nearly 5 years. Just a Rockford fosgate punch 150.2 running my front two 6.5ā€ door speakers. This used to be combined with other amps and subs so positive and negative battery wires are all 0 awg andĀ Amp is properly grounded, big three etc. everything was perfect. I recently decided to upgrade my door speakers and was trimming the plastic in my door panels to fit a deeper speaker, my glass was in the way so I put the key in for a second to roll the window up, and stupidly left the speaker wires dangling in the door skin and I heard the passenger speaker scratch, knowing I was shorting the wires in the door, I quickly shut it off.Ā I know better then to have the amp on while doing wiring but I was forgetful. Anyways after hooking everything back up I am now getting engine noise through the door speakers and a large bump when I shut the car off. What is most likely the fix for this? Did I fry my app somehow? It still powers fine and plays, Iā€™m just getting interference now. I know everything is hooked up good as itā€™s worked perfectly for years. Iā€™m thinking either my head unit ground melted a little or something has happened to my amp? Any help would be greatly appreciated as I have new speakers on the way
A little hard to read with no punctuation but did you mess with any of the amp or head unit wiring? start up thumps are some times caused by rca or remote wire issues
Iā€™ve not touched anything other then the plastic and metal in my door panel to trim for a speaker with a deeper magnet. The pos and neg wires for my driver side door speaker were pushed down inside my door while I was cutting and therefore when I turned the ignition on the toĀ roll up the windowĀ they must haveĀ been touching the metal effectively shorting the two together for a couple seconds. The only thing I have tried was disconnecting the left channel (the one that shorted)Ā directly from the amp to see if it would go away thinking I may have melted some of the speaker wiringĀ but I didnā€™t have time beyond that last night to troubleshoot further. Iā€™m getting a static when the headunit is first powered on, alternator whine, and a thump upon turning the headunit off. All of this was untouched working perfectly since the install for nearly 5 years, and only started after I touched the two speaker wires for a moment. Later I am going to try disconnecting the amp to see if itā€™s in my head unit as my rear stage is powered directly off the headunit and only my front door speakers are amplified externally
Well, i was able to unplug the rca cables from the amp and when I did this I was not getting interference on my rear speakers.. can anyone please give me any ideas about where to go from here or what I may need to check?Ā
I have Pioneer deh x4850bt and im not using any loc or dsp just an rca from the head unit
17
4K
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
213
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
537
Tons of options in that budget, including the cost of installation,
10
823
na96ek
na96ek
TN
na96ek
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
