Buzzing noise from subwoofer/amp
  • 1
Brett1210
CarAudio.com Newbie
I’m looking for some help with solving a buzzing noise that’s coming from area of the factory amp/sub enclosure. It’s a 2005 Ford F-150 Lariat. The amp and sub are underneath the drivers side rear seat.  About 4 years ago I replaced the stock head with a Pioneer App Radio 4, and upgraded the 4 door speakers as well.
Everything has worked great until very recently.  The buzzing starts after I turn the ignition to the ON position and the head unit boots up, even if there is no music playing. If I turn the key to off, the head unit stays on but the buzzing stops. The head unit only shuts off once a door is opened in my truck. I’ve tested it many times and it never fails - turn key on and it buzzes, turn key off and music is crystal clear with no buzzing.
I’m not sure exactly when this started. The only recent significant event was that my trucks’s battery went dead after I left it outside in the extreme cold for a week. I had to jump it and it really didn’t want to start since the battery acid had turned to slush.  Could this have damaged the amp?
Any suggestions would be very much appreciated!
Thanks for reading!
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
11
Got it figured out. The PAC LP7-4 LOC seemed to do the trick, and brought the noise down to a very quiet hiss similar to the stock radio...
4
Ok, last ditch effort; I assume the radio high outputs do work but are capped off at the moment. Try using a passive LOC, it will be cheaper than...
37
4K
Your math isn't so good. I made a mistake I'm sorry. I'm striving to be perfect like you.
5
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
Brett1210
CarAudio.com Newbie
Brett1210
Brett1210
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
