Added second battery. Problems with sound system.
  • 5
hotinferno
4
Cyprus
I have added a second car battery in the back and I have two problems:
a) Even though the head unit is not connected on the second battery, it still stays on even after I have removed the keys.
b) Amp01 (check diagram) doesn't work. (However it could be faulty)
Here's how I did the wiring:
Any ideas would be welcome.
Just use one ground in the back, it will make life easier. Ground the batt and from the negative term run 2 other grounds to the amps. This probably will not help your issue but, it's something I would change from what you have done.
is your headunits switched power wire run to a source in car that only turns on when the key is turned?
I would say you have your red wire from the head unit ran wrong.Check that first.Run the wire to a power source that shuts on and off with the car.
Guys thanks for the help but I figured it out. The problem with the remote was that it was touching the positive of amp01. The problem with the amp01 not turning on was because it didn't like the place I grounded it. I just moved the ground to somewhere else and it worked. Weird.
Thanks again for the replies!
What about the radio?
Does this harness have anything resembling an LOC? If not, I would guess that is the issue. I would test an inline passive LOC.
I have a 2018 f150, looking to keep factory head unit, not running a dsp as this is budget build. I have a t harness, skar doors, amp and subs...
So, why the fukk is the pedo replying to me? He started the shitt again and I am responding. What don't you understand?
75
8K
hotinferno
hotinferno
Cyprus
Nutdawg651
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
