adding a 2nd battery in a 2000 silverado
  • 2
Guinelle1
25
Chicago
i have a 2000 silverado and im looking to add a 2nd battery. i cant seem to find the part numbers for the tray and the clamp and stuff. ive found them where people are adding a battery where my stock battery is but i want to add my battery on the passenger side above the coolant resevoir. also how do i go about wiring it up? i plan to just wire in parallel so just one positive from the main battery to the aux battery and then ground the 2nd battery to the frame?
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
832
Thanks. That makes sense. It sounds pretty good as is.
Guinelle1
Guinelle1
Chicago
subzero
