adding more speakers to amp
  • 3
trilex
CarAudio.com Newbie
84738
Hi: To start off with I am no tech person, so bear with me. Running a 5 channel Pioneer D9705 with a SW and 4x 75 RMS channels. Each channel goes via a passive crossover to 4 Ohm speaker and tweeter. I like to add one more speaker to each channel, but am lost on how to deal with impedance, so not to overtax my amp. Any advice / schematic is welcome
Not really an option. If you throw another set of speakers on the fronts or the four corners, you'll drop the impedance 0n two or all 4 of the 4x75 channels to 2 ohms. for a 25 watt gain and no appreciable volume difference. What specific speakers, how are you thinking of handling the crossover situation? This usually ends up spoiling any semblance of stageing you might have, not thinking itis a course of action you really want to take.
What is the goal?
You won't "overtax the amp, you're going to underdo the speaker". That's already low wattage. With the crossover you're dividing up the frequency already to use two speakers per channel. Without knowing speaker details, you're about to cut the wattage down. If it's good leave it as is, and add another amp, or maybe power the other set off the head unit.
What is the goal?
Thanks. That makes sense. It sounds pretty good as is.
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
691
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
635
I have a jeep grand cherokee that is controlled by pcm but I have a external voltage regulator . I just switched to cmax and when I went to turn...
trilex
CarAudio.com Newbie
trilex
trilex
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
