adding alpine 110 tweeters
  • 2
dhilling
I'm installing a "used/New" system in a 2000 Jeep GC with my son. Anyway, the HU is a MEX-BT3000(used) which only has 2 RCA outputs. one is going to a 4 channel BOSS CXX1204 amp(powers 2 3-way fosgate front speakers on channel 1/2...3/4 is not used) and the other is going to a (used)sony xplod amp (for 2 10" subs). System sounds good (for me anyway) but he wanted to get more highs and replaced the factory tweeters in the dash with a new pair of alpin 110 with crossover.
Anyway, since the HU only has 2 RCA outs I connected the tweeters to the same connections on the BOSS amp with the fosgate front speakers. The tweeters do work but you can barely hear them. I am by no means an audio guy, but without replacing any/all of his equipment. Is there a better way to run the new tweeters? I called the place where he purchased them but they want $$ to answer any ?
I hope someone can point me in the right direction.
Thanks
Doug
I would connect thee tweets to the ch3&4. you might have to split the rca signal to have them work unless the amp has a 2ch 4ch input selector on it. that way you could push more juice through the tweets and balance out the sound.
Thanks for the reply, I was thinking I didn't ask the right ? since nobody was replying. Anyway, when you said to split the rca do you mean the rca from the hu that feeds my front speakers? cut/split them before the amp and connect to channel 3/4 too? then run my tweeters correct? I tried connecting them to the hd (built-in front, but you still can't really hear them)
dont cut and splice. they have a splitter that will plug into the rca's and give you enough for the 4ch from 2 rca's. but check the side of the amp first and see if there is a switch that say "input", "2ch-4ch"
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
823
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
736
Thanks. That makes sense. It sounds pretty good as is.
941
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
dhilling
dhilling
altoona, pa
CrossoverOre
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
