Adding diodes to get to 16v
  • 1
Bass so loud it HZ
CarAudio.com Regular
I have a jeep grand cherokee that is controlled by pcm but I have a external voltage regulator . I just switched to cmax and when I went to turn my voltage up it only goes up to 15v's. I just seen how to run diodes to up my voltage.could I add some diodes to my sense wire while still using the regulator? Don't want to have to mess with trying to run a potentiometer..TIA
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
781
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
690
Thanks. That makes sense. It sounds pretty good as is.
919
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
Bass so loud it HZ
Bass so loud it HZ
IN, United States
Bass so loud it HZ
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
