Adding subs w/o oem integration unit
  • 4
sobe3yourself.
lordside gangster
3,140
Orange, CA
Is there a way to add an amp and a pair of subs without putting an aftermarket HU or an oem integration unit (cleansweep, 3sixty...)
It's a 2008 honda accord with the premium sound system. It comes with a stock sub in the rear deck and im guessing an amplifier to power it separated from the other speakers. Is there any way to bypass this amp and power a low power amp (no more than 400 watts) without doing too much work?
I know you said you don't want to try an OEM integration unit, but the Maxxsonics MX1 and the MTX reQ-5 are MUCH cheaper than the 360 and Cleansweep. I had a MX1, and although I was unable to use it in my car it was very good for the price. Sold it to a friend and it worked perfect for him.
I don't see why you can't just take a Line-Out converter to take the speaker-level output from your headunit and turn it into a low-level RCA output that you can run to a separate amp. Your headunit may even already have RCA outputs since it's the "premium" version rather than standard; you should do some research to check on that.
Re-Q.....cheap, easy....and it works. Used one in the wifes tribute, to upgrade the factory sub. Bypassed the factory amp, and replaced the sub, and added a small amp.
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
5
826
Thanks. That makes sense. It sounds pretty good as is.
sobe3yourself.
lordside gangster
sobe3yourself.
Orange, CA
CHEMMINS
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
