Adding subwoofers without scrapping navigation
HoopDogg
Hello!
I'm new here and was unable to find this information in an old post.
I just leased a vehicle with naviagation and I want to put my previously used system in the new leased vehicle. I definitly cannot remove the navi because I'll loose almost all functionality of the dash. Is there some way I can just connect a wire to my subs to tell the amp to turn on (like the P.conn) and have a knob to adjust the volume of the subs ? Any help is appreciated !! Thanks guys !
Line out converter but about 90% sure you wont be able to use one, most factory stereos in newer cars have a seperate amp and even if not the speaker outputs are crossed over, a simple loc wont work cause you will be pulling the signal already crossed. You will need something like a jl cleansweep or an audiocontrol lc6 that will sum the input and give you a full range signal to work with
833
It is a little overkill with the batteries, but underkill with the alternator. Ideally, you want an alternator that will keep up with your system...
739
Thanks. That makes sense. It sounds pretty good as is.
944
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
HoopDogg
HoopDogg
Albany, NY
jdawg
    May 18, 2024
    May 18, 2024
