Advice On Finding A Quality Subwoofer
So i just got a new car (2014 Impala) and im trying to figure out what type of subwoofer i can get that can handle my amp and not blow, something that will last for awhile. And something that sounds decent and powerful. I would like to stay under $300 when buying this subwoofer. These are the things i already have in my car.
Hifonics BRX1000.1D
4 ohms: 400 watts x 1 chan.
2 ohms: 700 watts x 1 chan.
1 ohm: 1000 watts x 1 chan.
Ported Box (Single 12in. Subwoofer)
Box volume (net. int.): 2.0 cubic feet
Tuned to: 32Hz
Dimensions (W x H x D): 30" x 13-1/2" x 16"
Factory head unit and Factory Speakers (BOSE)
Any suggestions on what type of subwoofer to get???
If you keep blowing subs. It's more likely that your sending a clipped signal to it There are many subs that fall in the price range you have. Sundown tantric ascendant dc the list goes on
Hifonics BRX1000.1D
Tuned to: 32Hz
American Bass XFL- DVC2 ohm would be ideal to run @1 ohm load..DVC4 ohm for the 2 ohm load.Subs get downand sound nice doing it for the price
Hell if you send it a good clean signal an SA will take 1000rms all day.. Look at sound qubed hds3 subs . They have a 3" coil and will take stupid powa. They are like 150$ for the 12 if you really want to jump up to a tougher sub soundqubed hdc3 series are damm near bullet proof at 1000rms.
Main thing is (as already mentioned) is sending a clean signal to the sub.. You should not be blowing subs with a clean signal. I have fed a sundown SA 15 1800 rms daily and never had an issue but gains have to be set properly.
The SA, hds3, hdc3 will all perform decent in the box you have as well.
The x series is an awsome sub but a bit overkill for that power.. I would go SA or sq hds3.. Set gains properly and enjoy.
Ok. im going with the SoundQubed HDC3 12...Now on there website they give you an option of aluminum or copper voice coil. Does it matter which one i get???
you dont have close the amount of power to tickle that sub, let alone aluminum voice coils. They probably wont do too well on your box either since its a tad small.
So a suggestion then????? And im also not trying to rattle parts off my car or anything like that so if your saying my amp wont do that but it would give me some decent bass with that sub then im perfectly fine with that
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
562
It also lowers the amps efficiency and raises the current draw.
5
695
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
860
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
934
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
BigSteve757
BigSteve757
Virginia Beach, VA
BigSteve757
