advice on how to safely wash your car using a pressure washer
  • 1
benney_jonson
4
USA
I just purchased a similar electric powered psi machine (1600 psi) and I stupidly trapped my handy before side of the questionable turbocompresseur misting nozzle thing and I sensed like it almost took my handy off. What I discovered is, these machines put out questionable, but A much lower number of water then I'm used to with a garden water hose. So, this to me makes them not the best for washing off detergent, as the more discharge of
a garden water hose works better for me. In fact, my first time using the power machine, I got water areas on the screen I couldn't simply eliminate by clearing off. I had to use a gentle gloss by hand on all the windows (on a SUV no less) to get the areas off. I think these gadgets are good for an
initial apply down to eliminate as much reduce dust as possible. And, actually, I did cause a colour processor on my ceiling tray from treating too much stress to close. I have a Karcher froth gun on order, so I'll give that a try. I also tried an ONR mix in the detergent container as clean water and it didn't really seem to do much. Also, anyone use the garden water hose de-ionization narrow systems that AG sells? It seems as though they only help and don't provide a identify free clean, as the substitute mineral magnesium vitamin and calcium mineral ions with salt chloride - which apparently doesn't identify as horribly. Do these narrow systems provide a recognizable difference? There seems to be one type of narrow set-up made and the opinions aren't great.
Car Leasing Tips
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
551
It also lowers the amps efficiency and raises the current draw.
5
684
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
848
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
927
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
benney_jonson
benney_jonson
USA
benney_jonson
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
