advise on my system
  • 5
isstern35
Well i recently purchased a VW Golf TDI and i changed the front speaker and back.
i have a pair of Helix dark blue Component B62c
50 RMS///100 Watts
and in the back i have
Helix dark blue 6 coaxial
35 RMS///70 watts
today i bought a new head unit to upgrade from my alpine CDE-100EUB
i got my self a alpine CDE-111RM,,,,i upgraded because this one has HPF and more stuff to tweak.
not sure if they have these models in the states
next week i'm going to dynamat my 4 doors and that is when my new HU goes in.
I was wondering if i want to add an amplifier in the future. what should i look for.
Also should i buy an amp and a sub or should i amplify my speakers first.
Also can you guys give me some examples of amps i should look for.
The type of music i listen to is vocal Trance, pop, rap, hip hop, and the occasional jazz
im not looking to get a headache in my car,,,,i want some crisp sound and bass at the same time... any ideas guys?
bumppp,,,,,can anyone tell me some amplifier models that would work with my current setup
Should i amp up the current speakers?
Buy an amp and a subwoofer? instead
What is your budget and what are you really wanting to do with your system? Be realistic with the budget. It will be the biggest determining factor. If you say $1000, and can only afford $500, you will be left with half a system based on our recs. But if you have the cash and you say I have 1500 right here right now, what are my options, then you will have a full system. It also depends if you are capable enough to do the install yourself, or if you have to have it installed.
Everyone always sees the main costs too....amp subs, speakers, deck. Everyone always forgets the lil hidden costs. Wire, fuses, fuse holders, distro blocks, terminals, alternators, batts....etc.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
466
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
160AH lithium that supports a 12K system is pretty lofty! I've seen dual 24's or quad 12's that will do this. Most of what 've run across is dual...
361
isstern35
isstern35
Romania
dragnix
