Aero Port for two 8's
  • 2
Bobbytwonames
Trigger Man!
13,030
1,813
Vegas
My box is about 1.94 cubes after sub displacement. I'm just wanting to know what you guys would do if you aeroported the box. I am trying to learn the aeroport thing. From what research that I've done, I'm guessing that I need about 18-22 in2 of port. I want the box tuned to 33hz. TIA! If you want to talk ****, that's fine, we can do that too. Just a serious question though.
You wouldn’t need that much port area for aero ports. You’d need a 6 inch aero port to reach 18-22 sq inches. I’m 99% sure you couldn’t fit a 6 inch aero inside the box. Maybe with a significant piece of the port outside the box, a 6 inch may work. A 4 inch should do fine with that air space. You could do 2 smaller ports for looks, but it might diminish sound quality or output. I’ve always stuck to 1 port myself, even though 2 looks better to my eyes.
A 4 inch would only give me 12.57 in2 of port. A 6 inch would be around 28.2 in2 of port, maybe too much. The port has to fire up also, so, my box height is only 13". Thanks for the reply man. This **** is confusing.
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
725
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
898
Bobbytwonames
Trigger Man!
Bobbytwonames
Vegas
Bobbytwonames
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
