Need help first box build
  • 2
Imsohigh420365
CarAudio.com Newbie
I got 2 audiopipe txx-bdc2-12 subs that I need to box using 3/4 board. Im putting them in a 2010 dodge journey. Each speaker will be wired to their own boss ar2000m mono amps. Can anyone tell me if the attached file is a good box design for them or what would be ideal?
Having 2 subs in the same box/air space running off their own separate amp might be a problem. You’ll need to set your gains on the 2 amps with a multimeter to get them to power your subs equally. I would run these subs in 1-1.5 cubes per sub, port tuning 32-34 hz. If you are a rap/bass music listener, I’d do 1.5. If you don’t listen to rap much, I’d do the box a little smaller.
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
11
544
662
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
932
Imsohigh420365
CarAudio.com Newbie
Imsohigh420365
United states
SlugButter
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
