After much Buying/Selling building, I think I have a system
hemi4me?
Ok guys, thought I would share what I ended up with for my current car audio system. The car is a 2006 300C SRT8 and I was NOT going to upgrade the sounds... LOL Yah that changed quick.
I was going to add one small amp, and 1 12" woofer. I did that and loved the sound.
Well things change and here is the latest.
1. Deck stock nav deck I hear these are actually very good with 8 v out strange as it sounds.
2. Zapco SP4-SL small 4 band EQ
Max Output Level/Balanced: 16 volts
EQ Center Frequencies: 40HZ, 125 KHz; 1KHz, 12KHz
Max Boost Cut: +/- 18dB
THD + Noise:
3. Front stage amp Zapco 360.4
Bridged, 4 ohms: 2 x 180 Watts
T.H.D. + Noise:
S/N Ratio: >95dB
4. SUB amp Zapco 750.2 (thinking of using them 4ohm stereo)
Stereo, 4 ohms: 2x175 Watts
Stereo, 2 ohms: 2x375 Watts
Bridged, 4 ohms: 1x750 Watts
T.H.D. + Noise:
5. Front Stage Dynaudio 342
7" MSP-Woofer, 3" Soft-Dome Midrange, 1.1" Soft-Dome Tweeter
Frequency Response: 55Hz – 25 kHz
Continuous Power Handling: 200 Watts
System Impedance: 4 O
6. SUB stage 2 x Image Dynamics 10" (DUAL 2 OHM) infinite baffle
RMS Power Handling (Pwr) 50 to 400
Anyone have any idea how this will sound? Should be ok I hope... I am worried about a couple things. First I got the subs before the amp and I was thinking of using a very small sub amp. BUT I ended up with a larger amp that I thought. Does anyone think this will be too much power?
Another thing I worry about is the rear baffle, and all the vibration. I understand these need very little power to run in IB.
I am thinking I should make a kick for the migrange 4" and the tweeter, but I am not sure? Can anyone give feedback on that? I have a spot that they will actually fit in the dash (there are 4" speakers there now in the corners). OR should I put them in the dash, and mount the speakers in the pilars?
The EQ I am going to try to mount in the right side of the shifter... Here are some pics. Not sure how the fit will be.
Any input or thoughts would be appreciated! Thank you
ive had greater results from putting the 6.5 comps in the kick panels then the door i build a small enclose to house the 6.5 comp then put on the kick panel , and tweet on the dash , i am curently running my tweets on the dash and 2 sets of 5.1/4 in the door . im still deciding wheather to sell my comps or put them in the door as well with the othe comps but id like to put them in kickpanel i like the sound better more fuller i think and more clarity
They were awesomne man. The components and Coax speakers I shoulk have kept. Theyre amps were pretty nice too. I never ran any of theyre subs...
20
Buck, great idea. I did that tonight, and it actually didn't wheeze like a fat guy trying to run a marathon. I am going to put two windows that...
19
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
If your audio system constantly draws more amperage than your alt produces, it will drain your battery, to the point of the battery needing to be...
14
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
hemi4me?
hemi4me?
Scottsdale, AZ
hemi4me?
    Jun 1, 2024
    May 31, 2024
