Aftermarket Install Nightmare
  • 6
silvabelz
:mad::mad::mad:
Hope someone can help me with this one.
I have a 2019 Mitsubishi Outlander SEL and want to install a Kenwood Excelon DDX6906S head unit.
I have every adapter needed for install EXCEPT the ones that change the factory USB cables into USB male
plugs.
My question is: Are there adapters for this application or am I driving myself nuts looking for something
that doesn't exist?
Thanks in advance for any help you can give me.
It looks to me there are already adapters on those usb cords. Try removing them via the push tab, I’m betting there are male usb plugs inside those adapters.
If that’s not the case, and you can’t find what you need, just run new usb cords, but I’m pretty sure you won’t need to. The top picture is a dead giveaway.
I wish I could say that you are right... But I can't.
Opened up the dash again today and triple checked.
The ends are more like 4 pin connectors in a 2 by 2 pattern, although it does look like usb plugs from
the side.
Unless someone else has a solution I'm gonna have to run new lines. Hate to disassemble a brand new car, but I want what I want. DAMMIT!!!
Thanks for the quick response :)
People don't void their warranties right after buying a new car? That's weird... lol
But it's just a USB cable going to an aftermarket headunit. I don't know what warranty would cover that or what it could screw up.
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
616
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
942
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
703
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
silvabelz
silvabelz
Las Vegas
silvabelz
slater
    May 2, 2024
slater
    May 2, 2024
