Aftermarket interface
  • 2
No way to tell if the wiring is bastardized without looking for yourself. Wiring adapters are cheap enough at installer.com. That said there is...
4
664
High pitch whine is usually a grounding or interference issue or from using inexpensive signals cables run parallel to power/ground lines. Or, as...
6
So you have your main power wire which feed the current it needs. Your original HU would have had it, and you probably connected your new HU to...
774
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
jrouter76
jrouter76
jrouter76
Mount Vernon ,Illinois
Kickstand
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
