Head Unit Questions
  • 3
circle221
CarAudio.com Newbie
BC
Hello, first time posting here
I am upgrading the HU in my 2017 Forte for my SQ build. Have narrowed it down to 2 i think, Either the Kenwood Excelon DMX907S or Pioneer DMHC5500NEX. Only real difference it looks like is the Kenwood has 5v Preamp and Pioneer is 4V. I can get the pioneer on sale for $690CAD and the kenwood for $799. Does the 1v difference justify the $120 difference?
https://www.crutchfield.ca/p_130DMC5500/Pioneer-DMH-C5500NEX.html
https://www.crutchfield.ca/p_113DMX907S/Kenwood-Excelon-DMX907S.html?tp=73318
Also this might be a stupid question but I am using an Arc Audio X2 600.4 and the Input sensitivity is 200mV - 3.5v. How Will the new HU work if it is either 4 or 5v?
Thanks for your help in advance !
Are you planning on an external DSP since you are doing an SQ build? If so I would just find a cheaper headunit with the features you want and spend the rest on a good DSP. The Kenwood does have wireless Apple car play/Android auto though.
If your amp can only take up to 3.5 volts you can just run the headunit at a lower volume or turn down the RCA output level.
OH OH... I got this. Kenwood eXcelon's are good to full volume with no distortion. The volume should go to 40. My Rockford Fosgate 3Sixty.3 DSP wanted a 2v input from the head unit. As you know and have stated, the Kenwood is 5v. This 5v is at a volume of 40 out of 40. 2v is 36 out of 40. Mine is a Kenwood eXcelon DMX706S. Hope this helps.
Yes I will be adding a DSP some time down the road once I save up enough for a decent one. Today bought the Kenwood excelon DMX907S. Thanks for your help!
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
423
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
565
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
689
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
circle221
CarAudio.com Newbie
circle221
BC
circle221
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
