all the info i can get
  • 2
Colossus281
Ok i have a hhr and will be putting in a system. The porb is that my battery is in the back so i dont want to do the big 3. I was told that a Shuriken SK-BT60 60ah Battery wolud be just as good. So what do i need to know about having one. Thanks
this question has no actual subject - are you asking about a system in general or a battery?
upgrading the battery is important, but so is upgrading factory big 3 wires - grounding at a minimum. you still need the alt to charge the battery and power the system. the wires between the alt and battery are a source of resistance - i.e. voltage drop. upgrading those connections helps. I run a 68 AmpHr battery with 135 min Reserve Capacity.
how i upgraded my wiring:
H.O. Alternator replacement and big 3 wiring - Honda Accord Forum - Honda Accord Enthusiast Forums
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
788
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
First of all you would want to verify that it works. Next, don't expect to get much out of it. There's a rather finite life expectancy on...
I found the paper from when i was looking into compatible impedance's close to Bose HU... Cleaning out basement, lol found this and realize how...
14
Colossus281
Colossus281
Albuquerque nm
keep_hope_alive
