alpine 357
  • 1
If you want show quality looks get the momo.
If you excellent quality at a good price get the JL.
Alpine specs the amp sub channel at 100W @ 4 ohms. Not sure if the 5th channel can handle a 2 ohm load or not. If it can only do a 4 ohm load as they rate the power, you'll need a dual 2 ohm series wired to get your 4 ohms.
The amp may be able to handle 3 ohms on the seperate channel and in that case you would need the dual 6 ohm model parallel wired.
I'm sure Zane could tell you about Alpine's abilities. Give him a buzz.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
188
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
437
So far I have bought Kicker CWRT8D4 Subthump underseat enclosure for 8 LoopBack Harness from AIS 8 gauge Kicker wiring kit (Will run two 8 gauge...
13
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
coprhed12
coprhed12
charlotte
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
