overheated!! help!1
  • 3
cf680c2
ASIA
hi all... Am using a BOSS rev-800 to power up 2 12" woofers, the AMP went into protect mode after 1/2 an hrs due to high temperature.. is there anyway to reduce heat?? or the amp is not suitable for my woofers?? woofer spec: 4 ohm max 600w
Well, the amp is definately where the problem lies. Boss amps unfortunately are not of the highest quality and thier circuitry is far from suitable for car audio.
Likely the final impedence of the woofers on the amplifier was to low for the amp to handle therefore it went into protection.
Sorry for the bad news, but the amp has got to go.
Take it easy,
-zane
Lanzar, Power Acustic, MTX
all very cheap amps
not to bad
I agree the BOSS amps cant handel very much
Make sure thoes subs arent bridged...cause that amp im pretty sure cant handle a 2 ohm load mono
At least thats what it sounds ilke
MY POS 1500 Power Acustic amp does the same but I keep it super cooled so its fine
Originally posted by julian:any amps to reccomend? prefferably cheap amps
I have quite a few that could easily work for your system. Are you looking to stay within a certain price range?
There are several amps out there that are worth thier wieght in gold that dont cost an arm and a leg.
Take it easy,
-zane
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
192
Im pretty curious as well.I am wondering what all took place for the supply for the demand?
12
564
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
396
Agreed with this here. Since you have the unit pulled out of the car/dash...test it at your car battery directly for operation. very simple to do...
368
cf680c2
cf680c2
ASIA
zane
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
