Alpine cda-117 new version 4 volt pre-out's like brand new!!! With remote
ATN2DETAILING
BURBANK
ALPINE CDA-117 WITH REMOTE AND CASE LIKE BRAND NEW
ZERO BIT MUTING!!! A MUST HAVE IN SQ SET UP'S!
10/10
Features and Specification
SPECIFICATIONS
CEA-2006 Power Ratings
CEA-2006 Power Rating: 4 I? @14.4 V Ƈ%THD+N, S/N 80 dBA (ref.1 W into 4 I?), 18 W x 4
Max Power Output Ratings
Max Power Output: 50W x 4
FM Tuner
Tuning Range: 87.7-107.9 MHz
Mono Usable Sensitivity: 9.3 dBf (0.8 A?V/75 ohms)
50dB Quieting Sensitivity: 13.5 dBf (1.3 A?V/75 ohms)
Alternate Channel Selectivity: 80.0 dB
Signal-to-Noise (S/N) Ratio: 65.0 dB
Stereo Separation: 35.0 dB
Capture Ratio: 2.0 dB
AM Tuner
Tuning Range: 530-1,710 kHz
Usable Sensitivity (IEC Standard): 22.5/27.0 (A?V/dBf)
Disc Player
Frequency Response: 5-20 k A?1 dB
Channel Separation (1kHz): 85 dB
Dynamic Range (1kHz): 95 dB
Total Harmonic Distortion (THD): 0.008% (at 1 kHz)
Wow & Flutter (%WRMS): B.M.L.
Oversampling: 8x/352.8 kHz
Audio Signal-to-Noise (S/N): 105 dB
Connection for iPodA?
USB Requirements: 1.1/2.0
Max. Power Consumption: 500 mA
USB Class: Mass Storage
File System: FAT 12/16/32
MP3 Decoding: MPEG-1/2 AUDIO Layer-3
WMA Decoding: Windows Media' Audio
AAC Decoding: ACC-LC format ''/m4a'' file
Number of Channels: 2-Channel (Stereo)
Frequency Response: 5-20 k A?1 dB (Frequency Response may differ depending on the encoder software/bit rate)
Total Harmonic Distortion: 0.008% (at 1 kHz)
Dynamic Range: 95 dB (at 1 kHz)
Signal-to-Noise Ratio: 105 dB
Channel Separation: 85 dB (at 1 kHz)
Sound Tuning
Subwoofer Level Adjustment: 0 to 15
High Pass Filter: OFF/60/80/100Hz (Selectable)
MediaXpander Modes: Off / 1 / 2 / 3 (Selectable)
MediaXpander Aux Settings: FM, CD, XM, MP3, (Level 1, 2, 3, Off), DVD Video (Level 1, 2, Off), DVD Music (Level 1, Off)
Equalizer: 5 Band Parametric (63Hz - 17.5KHz, 1/3 oct. Steps)Adjustable level: ƌ to +6 dB Adjustable bandwidth: 1, 1.5, 3 or 7 Band Graphic Adjustable output level: ƌ to +6 dB
Time Correction: Adjustable Time Correction (L-F/R-F/L-R/R-R/L-SW/R-SW)
Remote Control
Remote Control: Included
Model Number: RUE-4202
Battery Type: AAA Batteries (2 pcs.)
Weight: 50 g (1.8 oz.)
Dimensions
Din Size: 1 DIN
Chassis Size (W x H x D) mm: 178 mm x 50 mm x 160 mm
Chassis Size (W x H x D) in: 7'' x 2''x 6-1/4''
Nose Piece Size (W x H x D) mm: 170 mm x 46 mm x 24 mm
Nose Piece Size (W x H x D) in: 6-3/4'' x 1-13/16'' x 15/16''
General
Power Requirement: 14.4 (11-16) V.DC
Pre Output Voltage (Before Clipping): 4 V / 10 k ohms
Operating Temperature (A?C/ A?F): 60 A?C (140 A?F) to -10 A?C (14 A?F)
Maximum Mounting Angle: 35A? from Horizontal
Weight: 1.6 kg (3 lbs. 8 oz)
FEATURES
Tuner
Memory Presets: Preset Stations (FM:12 / AM:6)
Memory: Auto Memory
Seek Mode: Local / DX Selection
RDS
RDS Functions: PTY, TP, CT, Radio Text, TA
iTunesA? Tagging: RDS iTunesA? Tagging
HD RadioA?
Built-In or Ready: Built-In or Ready HD Radio' Ready
Connection: Alpine TUA-T500HD / TUA-T550HD Required
Signal Switching: Automatic Digital / Analog
Multi-Casting: Multi-Cast HD1,HD2,HD3
Supports iTunesA? Tagging: Supports iTunesA? Tagging (TUA-T550HD Required)
BluetoothA?
Built-In or Ready: Built-In or Ready Parrot Bluetooth Ready
Connection: Alpine KCE-400BT Required. Features may differ between phone model and service providers.
Hands Free: Hands Free Calling
Phone Book: Phone Book Transfer
Streaming Music: Streaming Music Playback
Streaming Music Control: Streaming Music Control
Adjusting the volume when receiving a Call: Adjusting the volume when receiving a Call
Redial Function: Redial Function
Call History (Dialed, Received, Missed): Dialed, Received, Missed
Voice Dial Operation: Voice Dial Operation
Made for iPod/iPhone: Made for iPod
Works with iPhone: Works with iPhone
Connection Type: Connection Type USB Connection
Connection: Connection USB Cable Included
M.I.X. (Shuffle) Capability: M.I.X. (Shuffle) Capability Song, Albums, All
Music Control: Music Control Up / Down / Repeat
Available Selections: Available Selections Playlist, Artist, Album, Song, Podcast, Genre, Composer, Audiobook
Percentage Search: Percentage Search (Direct Search Function)
Alphabet Search: Alphabet Skip function
Information Display: Information Display Artist, Song, Album
Easy Navigating: Easy Navigating Quick Search
Connection for USB
USB Connection: USB
USB Input: USB Input Back Side
Connection: USB Cable Included
Music Playback: MP3/AAC/WMA Playback
Banking: Max. 20 banks (20,000 songs)
Satellite Radio
Built-In or Ready: Built-In or Ready Satellite Radio Ready
Connection: SIRIUS or XM Adapter Required
Satellite Provider Capability: SIRIUS or XM
Preset Memory: 3-Bands (6 Per Band, 18 Channels Total)
Easy Navigating : Quick Search
Music Information: Category, Artist, Song
Portable Compatibility: SIRIUS Plug N Play Devices (Adapter Required)
Disc Player
Disc Type: CD Player
Disc Playback Type: Type CD/CD-R/CD-RW
Compressed Media Playback: MP3/AAC/WMA Playback
DAC: Burr-Brown DAC
Zero data Mute: Zero data Mute
Digital Servo: Digital Servo
Music Sensor: Scan/Repeat
Playback Control: Play/Pause/Forward/Backward
M.I.X. Mode: One (Folder) /All (Random Play) /Random (CD Only)
Easy Navigating: Quick Search
Sound Tuning
Subwoofer Level: Subwoofer Level Adjustment
High Pass Filter: High Pass Filter Adjustment
MediaXpander: MediaXpander Feature
Time Correction: Time Correction Adjustment
Equalizer: Equalizer 5 Band Graphic or 7 Band Parametric Equalizer Feature
IMPRINT: IMPRINT Sound System Ready (PXA-H100 Required)
CD Changer Control
M.I.X.: One/All (Shuffle)
Multi-Changer Control: Multi-Changer Control including MP3 Changer CHA-S634 (with KCA-410C)
Music Text Information: CD:Text Scroll Display, MP3: Text Information Display (ID3 Tag)
Music Control: Play/Pause/Forward/Backward
Repeat: Song/Disc
General
Power Output: Max 50 W x 4 High Power Amplifier
CD Changer: CD Changer Control
Display: BioLite Display
Control Type: Rotary Encoder Knob
Face Color: Black
Illumination Buttons: Blue Illuminated Buttons
PreOut: 3 PreOuts (4 V)
DAC: Burr-Brown 24-bit DAC
Auxiliary Input: Versatile-Link Ready (KCA-121B Auxiliary Input)
Steering Wheel Control: Steering Wheel Control Ready
Selectable Power Input: 2 PreIn (Front / Rear)
Bass & Treble: Parametric & Graphic EQ
Fader & Balance: Fader & Balance Controls
Clock: Built-In Clock
Calendar: Built-In Calender
DIN Trim Plate: Detachable Trim Plate
Detachable Face Plate: Detachable Face Plate
Dimmer: Dimmer Input
Power Antenna Lead: Power Antenna Lead Output
Remote Turn-On: Remote Turn-On Output
Audio Interrupt: Audio Interrupt Input
Remote Control: Remote Control Included
$199 FREE SHIPPING WITHIN THE U.S.
no more high end decks from alpine ,from what i'm being told ,unless its a dvd or navi unit.at least nothing like the cda 117
The alpine dealer in my town has said the same thing... They think it's more about marketing strategy from Alpine
Absolutely is the case how else are goIng to sell the same thing over and over you loose market appeal and loss in incremental units sold basic business 101
I'm leaving on a business trip this Sunday and would like this piece sold... I just lowered the price another $30 and including shipping!!! Good luck
Hey everyone,
leaving for a business trip this weekend so its that last chance to get this unit sent out this weekend... I'm also paying for shipping so pm or better send me a text if you want the unit... Thank you
Alex
714-290-1243
Thank you! I never understood that mentality! Does it matter if I got it for $800 or $50?? lol I'm selling for $$$ do you want it? thats all... Sorry I had to vent lol
I never understand people putting their number out there like that.......
Anyway, sweet deck, awesome price. I was a hair away on one of these. Honestly don't need all the functions this does, hence going a different route.
For those who PM'd me... This unit has full capabilities for RTA real time alignment, cross over 3 way with switch, and much much more...
This IS a nice unit for that price. Sounds waaay better than the $800 Pioneer flip-out I had. Now I just need Xhibit to hook me up with processors so my processors can be processed while they process.
I recently bought this exact bt adapter for a cda9813 and it works flawlessly
914
That’s really helpful, thanks! I’ll keep digging and see what I can find online :)
4
I'm hoping to find someone who might be able to repair this head unit. The faceplate doesn't slide out at all.
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
256
ATN2DETAILING
ATN2DETAILING
BURBANK
ATN2DETAILING
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
