Alpine PLT-5 powered subwoofer 250RMS
gnesterenko
Alpine PLT-5 250RMS powered subwoofer
# amplified subwoofer system with Linear Array Transducer (LAT) technology
# six 5-inch woofer cones in Ultra Reflex subwoofer box
# Alpine PDX 250-watt RMS digital amplifier
# variable low-pass filter (50-200 Hz, 24 dB/octave)
# bass boost (0-12 dB @ 45 Hz) with wired remote control
# subsonic filter (15 Hz, 24 dB/octave)
# phase control (0, 180 degrees)
# speaker- and preamp-level inputs
# 8-gauge power and ground leads recommended
# 21-5/8"W x 13-3/8"H x 8-7/8"D1 x 6-3/16"D2
# 47 lbs
Detailed Link: http://www.crutchfield.com/S-VDFU1O2ZYb8/p_500PLT5/Alpine-PLT-5-br-LAT-Subwoofer-System.html
These got a lot of flak for powered subwoofers, but from personal use over almost 2 years, this thing is perfect entry level sub for someone who just wants a no-hassle install without needing to worry about a separate amp. Plenty loud, never over-driven, and always crossed-over in the 80-85Hz region.
Functionality: 10/10
Cosmetic: 6/10
Runs perfectly, but has seen better days in terms of looks. A bit dusty and does have a few very minor scuffs on the chassis - nothing to affect function at all. The only thing I could find wrong with it: the side panel hiding the wiring connections snaps on to the sub using 8 plastic snap pieces/clips - of these 3 have broken. This doesn't impact how secure the side panel is - stays on there just fine. See pictures.
$230 OBO shipped. A bit on the high side, but this thing is heavy, and shipping is pricey.
$180 OBO for local pickup.
Got it new and have been the only owner, running it for a bit over a year in my old car. Got rid of the car and upgrading to something with a little more power for my next build, so no reason to hold on to it.
Can also include an amplifier power kit (power/ground/fuse/turn on lead - no RCA) for an extra $10 if you want.
Local obviously easier/faster/preferred. Otherwise will ship with USPS. Payment through PayPal Gift STRONGLY preferred unless local, then cash of course.
Would you be willing to trade for an Alpine 9835 and the iPod adapter, KCA-420i? The 9835 is pretty nice, the 420i has some marks on it from being mounted. You don't see the 420i though so that shouldn't matter. Let me know.
Sorry all good on amps at the moment.
Dimentions are in the OP, but here they are again just in case:
Width: 21-5/8" (without mounting plates, add another 3 inches or so at the base)
Height: 13-3/8"
Depth @ base: 8-7/8"
Depth @ top: 6-3/16"
Weight: 47 lbs
The cutting it off part is what I'm confused about now. The speakers in my car have two wires coming off of them but I would only have one wire on...
580
The Type R subs are a really great sub. Deff ask about a DMM reading or take a DMM and check them. Dust Caps can be replaced as stated and...
7
806
FOR SALE Alpine PDX-V9
As the title states, I'm selling my Alpine PDX-V9. This is a 5-channel amp, with 500 watts being delivered to the sub channel (2-4 ohms) and 100...
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
gnesterenko
gnesterenko
Philadelphia, PA
gnesterenko
Decebal
    Jun 10, 2024
