Alternator Mystery 10.00 Pay pal
sleazebagger
nobody!!!
3,337
Madison, WI
Spent the whole fukin day trying to get this to work. If you can figure it out I'll paypal you 10 bucks. God help me!!!
Spent about 2 hours on the phone with mechman. Triple checked all connections and continuity. Followed mechmans directions to a "T" on bypassing the factory harness and sending a straight power signal to the alternator from battery(for testing purpose) and also tried using an ignition signal to try and get this to turn on.
Finally switched out back to the old alt and all is well except that mechman has no clue and I have a perfectly good alt that doesn't want to charge at the proper voltage.
I hope this video will help explain.
I have a nasty cold so excuse my sniffles:(...
http://www.youtube.com/watch?v=hvaqwGxoG0Q
Update:
Had my buddy come over. He re-wired and tested everything every which way and then he hooked it up with only the factory harness to the alt. He had me test the system at full tilt. Turns out it runs @ around 12 V's with no dimming @ full tilt. Voltage reading was just bouncing almost all the way down and still no dimming or degradation.
We cranked everything up to its max and ran it for about 15 minutes. Sht was cleaner and harder then ever!
Then.... in all the confusion of WTF is going on here with this thing I put in some super low stuff and the whole system turned off and came back on in less then 5 seconds. I imagine it dipped well below 12v and the HU said fuc off
If I didn't have a clue then I am really fukin stumped now.
I honestly dont think anyone will be able to solve this so I'm bumping the reward up to 20.00.
My friend is a 15 year veteran and for now..... he's stumped until further research
i had something similar to this happen with a ho alt back in the day on my grand am, basically i wound up having to tighten the tensioner down about as tight as possible to get the belt to engage onto the pulley tightly enough to get full performance out of it. even if it looks like the belt is tight, those new belts and pulleys can be slick and need to be super tight against each other to have enough friction to work correctly
This has a spring controlled tensioner, so it's not like the old days where you can hang on the alternator to tighten it all up.
And with no real current draw (testing done with stereo off, right?), I'd expect it to be able to maintain a good voltage at idle even with some slip.
Disconnect the wires from the alt output bolt and start it. What voltage do you see at the output stud with no wires on it?
about 12v
---------- Post added at 07:39 PM ---------- Previous post was at 07:38 PM ----------
the pully is tight and the belt i have on is optimal for this alt. alredy been down this road. first thing I checked.
---------- Post added at 07:40 PM ---------- Previous post was at 07:39 PM ----------
This has a spring controlled tensioner, so it's not like the old days where you can hang on the alternator to tighten it all up. And with no real current draw (testing done with stereo off, right?), I'd expect it to be able to maintain a good voltage at idle even with some slip.
Thanks but theres no slip what so ever
This has the Ford 3G alternator stock, correct? It sounds like the alternator is just not turning on as it should.
You mentioned jumpering battery to the alternator for the turn on. Which wire did you attach that to?
The green/red. Mechman said that was the alt turn on.
Another guy had problems with his on CACO too. Are vehicles are just terrible vehicles when it comes to electrical. Have you thought about running an independent voltage regulator?
Hello I also have a question I want to buy 160ah lto, i.e. 4 banks but I have a stock alternator of 140 a and a maximum load of 14.9 do you think...
Okay cool bc I'm thinking about getting 5k amp and just wasn't sure if that battery would do but I appreciate all the help
18
I don't have one...but I check my voltage with a dmm once a week or so
12
You just found your own solution. Move the DSP elsewhere. The RCA is triple protected but not the RCA plugs. I do not know if there is a mesh or...
sleazebagger
nobody!!!
sleazebagger
Madison, WI
I Like Waffle
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
