how many ohms would be if i hooked up 6 subs 4ohms each
05trailblazer
k33p groaning son :)
2,114
Dallas,TX
i just want to know how many ohms my amp would be looking when ever i hook up 6 subs that are 4ohms each?? i know if i hook up 4 subs that are 4ohms each and i wire them up in series they drop down to 2ohms how many ohms would they drop down if they were six subs ??? my amp is a 2ohm stable.
wired in series ---> ohm + ohm + ohm + .....
wired in parallel --> 1/ohm + 1/ohm + 1/ohm + ..... then take the reciprocal...
if all six are wired in parallel=== 1/4+1/4+1/4+1/4+1/4+1/4= 6/4 --> 3/2. Now take the reciprocal, 2/3 or .66 ohms
6 subs and each are dvc 4ohms i know if i wire 4subs that are 4ohms each in series they drop down to 2ohms i want too add two more 4ohm dvc subs how many ohms will my amp see when wired in series? not parallel
12ohms??????mmy;7669132]wired in series ---> ohm + ohm + ohm + .....
6 12's powered by a zx.1500 kicker amp i bet its loud. vehicle trail blazer //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Epic failure in this thread. 6 dual 4ohm subs = 0.33 when all coils are parallel and 1.33 when series parallel.
Alright sorry this took so long. Here's the update. I tried out all the sets of speakers, the black diamonds did not fit front or back. I think if...
23
4K
5 ch amps can get expensive and most of the sub stage lacks power for a decent mid-sized sub. And end up running hot. Some times its best to look...
11
This is a little more money but well worth it from looking at the reviews. And it's Korean.
13
I wouldnt waste the time or money on OEM speakers to be placed back into any vehicle unless you plan to sale the vehicle and remove the after...
4
With half inch MDF, it's like 4.27cu/ft internally not including sub and port displacement. That's like 3.5 to 3.8cu/ft after displacement. You...
05trailblazer
05trailblazer
Dallas,TX
Kangaroux
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
