Alternators-Newbie
  • 4
Hey guys whatsup iv been told that with the sound system i want its better to go with an HQ alternator than extra batteries. I have a 1999 F-150 extended cab lariat 4x4. 5.4L triton. I don't know if that matters but yes i do need to do more research and i don't wanna here complaints from yall cause I'm a newb. Just please suggest and help me find a good alternator for my truck.
Thanks you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
This is what i have found so far.
http://www.qualitypowerauto.com/catalog.php?category=5
If you are running under 2k watts rms @ 2ohms you can really just run a zero gauge big-3 install and a nice deep cycle battery under the hood for insurance.
No extra batteries..
No high output alternator..
Just a big-3 for voltage issues, and a nice D31 Optima to replace your stock battery.
Your stock alt is either a 110 amp or a 130 amp iirc meaning you have between 45 and 55 amps to run your system on the stock alt..
A clean 1,000 watt amp pulls around ~50 amps.
Therefor you don't need an alternator.
If you choose to go 1k watts rms or higher @ 1ohm you will need to upgrade your alternator. Then depending on your listening habits, you might need to add a battery depending on your voltage dropping issues, if you're having any.
I've got three years on my 320a iraggi. I haven't used any other brands so i can't say how it compares to others. Customer service was great...
Cat as in animal. I had it sitting out on in the box with the box open as I grabbing some connectors from the other room as it was on the one...
14
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
924
That blue wire with the "remote control" sticker on it: It's NOT a remote control wire. Its a remote... control wire. Its a switch that...
Reece Cook
Reece Cook
Gonzales, Louisiana, United States
Reece Cook
Decebal
    Jun 10, 2024
