Need input, building my first subwoofer enclosure
  • 2
Jrm012
Hi everyone, i am looking to build my first enclosure. I have two nvx vsw 12's and a hifonics brx1100 1d in a sealed box. I am doing as much homework as possible because i want to build the perfect box (ported) for my subs and do it correctly. I have a few questions so far before i say yes to a specific layout for the box. I have a hyundai tiburon (which is a hatchback) and want to know if i should face the subs toward the back on the trunk or face them up toward the hatch? I want to get as much out of this system as possible. Any input would be appreciated.
I had 2 of the 10's a while back. Not bad budget subs imo. They sound wayyy better in a ported man. Usually with a hatch, subs up port back is best.
Port toward the back of the trunk? Yeah for now im gonna run this setup and when the time is right and i get an suv im going to go all out.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
149
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
110
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
455
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
350
Jrm012
Jrm012
New york
Jrm012
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
