amp and sub matches that are good
will be running this vertical behind sub box , right behind rear seats. i also will be building a cooling box with 4 4 inch fans, 2 push and 2 pull, they will probably be facing up towards the rear deck, so i have room for adj on the settings of each amp. the abs will probably be screwed to a puce of 1/5 inch plywood or to a piece of 3/4 inch mdf. i dont think its string enough to support the amps and everything by itself.
i think i found a thread that explains it , it just doesnt say about 2 amps, but i think i have the gyst. is it better to have a separate ground for the rear battery, rather than tying it in with the other ground. is it safer?
i have another question.. i have the ct sound ct-150-4D amp, to run front speakers. PowerBass OE-652 are 2 ohm speakers. amp says it can run them. does anyone have any experience with these speakers? i have already done killzmat and foam. am ripping out rear deck speakers as we speak. running wires to rear doors is gonna be a pain. wondering if these will be enough to fill cabin with enough sound. does anyone have any other options or speakers. i have kicker 4 ohm in the front doors now. i am working against the hurricane coming this way. should be here thursday. am losing wed and thurs for appointments. any help is much appreciated. thanks.
203
760
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
832
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
863
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
watcher6342
CarAudio.com Regular
watcher6342
hortense ga.
Silicon oxide
