Amp choices for fosgate pl3 210
  • 1
Metalbob
Hi all,
Im a little confused on which amp to get for the RF enclosure i have , its a pl3210 dvc 800 rms
I have been checking out the following amplifiers
RF prime750 - i would run this at 1 ohm to get the most from this amp
Hifonics Brx 24001d- i would run this at 4 ohm to get the 800rms, with room to grow, if i upgrade the subs.
RF prime 1200- this is the one im in the one where im up in the air about. If i run it at 1 ohm for the max rms, would i blow my subs even with the gain turned all the way down?
My current amp is Low end planet audio 1600. After 2 days i realized i was severly under powered and just keep my volume where it sounds nice in the car with some bass, i havent had bass in 14 years and i am really loving it and i want More. I am looking to purchase a new amp this week.
My HU is a jvc kd hdrxr52
Thanks everyone.
Mb
OK well I thought the same after watching the Audiofrog video of Andy explaining damping factor. I have to agree with you as well on the D class...
8
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
308
6
452
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
741
Metalbob
Metalbob
San Diego, CA
Metalbob
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
