Amp diagnosis
  • 1
nhegde
Hi, I am new to this forum and was looking for some help/suggestions. I had a car battery drain issue and my mechanic did a draw test and told me the amplifier was at fault. He said it does not shut down sometime and draws 0.5 amp of current when it fails to shut down. He recommended I have a car audio guy take a look at it. I had the amp and HU installed when I was living in Dallas 5 years ago. It is a aftermarket JL audio amp. I don't use the audio system much and it works fine when I use it. I am hoping I don't have to replace the amp. Is it possible to install a relay to help shut down the amp when the key is removed from the ignition? Any recommended places in central NJ that can help.
Thanks
Thanks for all the advice. Ultimately, I was able to get them to honor the warranty contract. It took a lot of back and forth and I received...
7
201
Never said they were. Commentary was more to being able to purchase one or the other or 40% off and take a 90 day warranty... which I would in a...
12
234
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
4
182
https://www.amazon.com/dp/B07DLC9M48/?tag=caraudiocom-20
25
421
nhegde
nhegde
millburn, nj
nhegde
chipss36
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
