5-6k amp
  • 5
Well for box rise that's why bc I'm only outputting about 1200 watts of 3500 watts so I figured with a 8k I'll get the full 3500 watts without it being hot
Not exactly how that works. You'll end up toasting your subs or possibly the amp trying to overcome impedance rise. If you want to have additional power if and when you have more drivers or higher powered subs, that's different story. You cannot mitigate impedance rise, fact of life.
But I thought if I got let's say a 5k amp and the output only is 2500k watts then if I say I got an 8k and got a 3k watt output with the gain right then the subs would be getting underpowered and shouldn't blow them?
That's correct, you can do that for sure. You cannot set it up to overcome impedance gain though, that's physics. Nothing wrong with getting a brute of an amp and setting the gains conservatively to accommodate the RMS of the subs you have currently. I'll be doing as much with my SD 2400.1 going to a pair of 400 watt RMS Focal subs. The Soundigital EVOPS 2400.1 puts out 1590 at 4 ohms which is twice the RMS rating of my subs. The gains will be set very conservatively and everyone will be happy and cool to play together.
That's exactly what I'm doing I'm gonna get the 8k and watch the output if it excess without clipping or 3k then I'll turn it down to match the 3k but if I have it right before clipping and still not hitting 3k then I'll leave it at that so that I don't blow the amp or my subs 😁😁
Try one of taramps smart line...they do about the same power at 1 or 2 ohms
And honestly unless you're playing tones for numbers...you'd be surprised how little power subs actually get with music, even at full knob 😂
The umm1 is just a rebadged dayton/minidsp mic. I personally have a umik2 and use a regular usbc-usbc to hook it up to my laptop and a...
8
191
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
171
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
135
Mr FaceCaser
CarAudio.com Regular
Mr FaceCaser
Charlotte
Doxquzme
pfft
    May 1, 2024
pfft
    May 1, 2024
Latest topics
