Amp for id cxs 6.5s
Title pretty much says it all. I posted about something like this about a month ago and everyone was very helpful, but i would really like to get some opinions on which amps i should be looking at to power these components
CXS64 V.2 - Image Dynamics 6.5" 4 ohm Component System
I would say my budget for the amp is around 300 dollars unless anyone can convince me of a reason to spend more. Please do give any and all suggestions!
Would like to add that i could get the 2 ohm version of the speakers instead of the 4 ohm ones if that would be better
Active or passive
Grab a mint ts 150x4 and smile at the 280+watts per channel @2ohm. Pure beast and can be used to let u run full active. Rd 200-250 all day
I was 100% planning on running the spakers passive since i'm relatively new to all of this. The thing i'm really confused about is how everyone is recommending amps with different amounts of power for the same speaker. What amount of power is actually best for these or what is the difference? Sorry to ask so many questions, but i'm just trying to make sure that my system turns out nicely =p
Thanks so much
You don't think that the 180 watts per channel the arc 300.2 pushes would be too much considering these speakers are rated at 125? I tried looking up what people have run them on and how they handle x amount of watts without finding much :/
MRX-F30 - Alpine 4 Channel 50W RMS Amplifier
D300.4 - Diamond Audio 300W RMS 4-Channel Class AB Amplifier
MRV-F300 - Alpine 4-Channel 300W RMS Amplifier
MIKRO IV - ZED Audio 4-Channel 440W RMS Advanced Class D Design Amplifier
SAE-50.4 - Sundown Audio Monoblock 300W RMS Class AB Full Range Amplifier
Could anyone please tell me of any of these would be a good pairing with the cxs64s that i've been looking at?Should i be looking into 2 channel amps instead of bridging 4 channel amps like these?I'm also curious to hear why one is better than another out of this group if you could be kind enough to educate me. Really want to get this last piece of my system decided on and ordered!
Thanks again
the arc will only putout 180 if you set the gain to do so. you don't have to send them 180. the arc is by far superior to any of the amps you listed. the CSXs can handle the 180 for music BTW
133
  • Locked
314
Amp
309
369
blackpanda1992
salisbury MD
Majik
    May 18, 2024
    May 18, 2024
