Amp for SSA GCON 12?
  • 4
So I'll be getting a 4 Ohm GCON 12 from someone and looking for advice on an amp. I have a Alpine mrp-m1000 that I can wire 1000 watts @ 2 ohms and was wondering if that would do the job? Or would it be worth to go bigger? Also, any suggestions for the box would be greatly appreciated. Will be going in the back of an 05 Mitsubishi Galant
I'm guessing that's after all displacements? And to the ear how would 30hz sound vs 33hz?
Depending upon how good your ears are, 30hz will play lower notes than tuned at 33Hz. I've had both...in fact my 15's are tuned to 30 I know that's a far stretch from the 12 but still. Just to give ya a general idea. The 33Hz tune may cover upper freq better than the 30 hz tuned one.
Yes, 2.25 after. Depending on where your cabin peaks, the 33hz will likely give you slightly higher peak spl, while 30 a touch more low end.
That is a good match up for Gcon. Hope to see some install pictures.
Thanks for the advice yall. I ended up finding a great deal on a new Soundqubed 2200. Went with it in case I end up upgrading later. How much can the GCON take safely?
It will take that amp at 2ohms no problem
And good call on leaving upgrade power. Amp would be perfect for 2 gcons at 1ohm
See above post from kr15. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
6
133
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
314
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
310
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
369
ATC_DJ
ATC_DJ
Montgomery, AL
kr15
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
