Sub box questions
  • 4
Dclm
I have 2 power acoustik mofo 15 subs. And I currently have one in a 3.5 cu ft ported box and I would like to have duals in my truck. And I cant find any dual 15 in ported sub boxes that are around the recommended cu ft for the sub. Anyone know of any dual sub box that is right around 3.5 cu ft per sub? Or does anyone know the recommended size for sealed box for the mofo 15? I can't find anything online for sealed box dimensions for the subs. Any help would be appreciated.
I don't think it has to be sealed. I haven't had time to do the big 3 for the wiring upgrade. But I plan on doing that when I switch to dual alternators this week (if I'm not to busy with work.) And my music preference changes daily. But majority of the time it's rock, heavy metal, or dubstep.
be hard to put 2 15's in truck (friend has problems putting 1 12 ported in truck under back seat) I'm sure they can be ported but I don't know how u would do 2 at all much less ported with right airspace..
Currently I have a 6000 watt amp pushing the one sub. I'm pretty sure ithat has enough power to push both subs. Since it's only turned up maybe an 1/8 of a turn.. no one near me makes custom sub boxes. And the closest place is about 4 hours away.
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Big subs have heavy cones. Heavy cones plus high power requires solid anchoring and solid enclosures. Most people don't anchor their boxes to the...
16
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
A little DAP will do ya, drill, feed & seal, done.
727
Dclm
Dclm
Douglas Wyoming
Dclm
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
