Amp goes into protect mode with heavy bass at medium to high volume
On top of the other things suggested , i say your starting battery may be weak. I drove my 97' civic for 12 years and never had a problem handling 700W. that said, try a buddies sub just to rule it out.
The amp reads about 12.45 volts when music is playing normally, and when it goes into protect it barely drops to about 12.41.
Where are you measuring this? It needs to be at the amp inputs, literally the screws that tighten down the cable.
I bet thats your problem right there. You don't have a good enough electrical system to supply the amp. Whats the voltage at the amp when it goes into protect? You only have 30-40a to supply the amp, if it needs more current your voltage will drop.
This sounds like the issue as well. The higher volume on the HU, the more amps are being pulled from alt, supplying power to amp, and thus cannot supply any more at high volume because it's too weak/not strong enough therefore amp goes into protect.
Has the big 3 been done yet?
So the big three improves current flow, which is most likely the problem, even though the voltage drop was negligible. Am I measuring voltage at the right place, or should I be measuring it at the subwoofer terminals or somewhere else?
Do you think I could connect jumper cables from another car to the battery to boost the power and confirm whether or not the battery is the problem?
Or would it be better to try a newer, larger battery from another car?
i can tell you with high certainty that the most likely culprit to this issue is the fact you used an angle grinder and not a wire brush or stripping wheel to remove paint, thus gouging of the contact surface between lug terminal and chassis ground reducing surface contact,... that's all i can think of using the process of elimination other than the amp being shot.
It did it immediately after first powering up the system, so I doubt the amp is shot. The angle grinded part is pretty smooth, but I drilled through the ring terminal to make the hole bigger to fit around the seat belt bolt, effectively reducing its contact patch with the chassis. Is this most likely the problem? Should I get another ring terminal and find another place for the bolt where I don't have to drill a bigger hole through it?
if you are measuring 12.4v when the amp protects i dont think its not a power issue. you will be able to measure low voltage at the amp terminals and it probably wont protect until 10.6v
what about running just one channel?
try switching if it still happens
i have a jbl amp that if i connect a speaker to the left rear channel the amp has no sound. disconnect it and sound from the other channels
Drilled hole, no. However, if the remaining contact area was grinded away with the grinder around the area of the hole will have an affect to it.
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
6
89
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
264
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
285
zavvier
zavvier
San Francisco
Boomin_tahoe
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
