ParaMattic
So I have a Lanzar OPTI 4000D and I can't figure out what kind of fuse I need. Is there something I'm missing? I've looked in the manual, on their website, and went to like the 5th page of Google. No luck.
You fuse for the wire you are running not the amp ..its to protect the wire not the amp //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif if u have 1/0 cca use 250 if u have 1/0ofc use 300So I have a Lanzar OPTI 4000D and I can't figure out what kind of fuse I need. Is there something I'm missing? I've looked in the manual, on their website, and went to like the 5th page of Google. No luck.
Will do, thanks. It may be a little while before I get a battery. I just regrounded my alternator today.. Hopefully everything runs smoothly once I get it all put in!All of ur bigger amps dont have internal fuses ..i havent had a sub amo with fuses in years..ditch the cap and buy a good agm battery
Gonna have nasty voltage drop until you do...Will do, thanks. It may be a little while before I get a battery. I just regrounded my alternator today.. Hopefully everything runs smoothly once I get it all put in!
