Amp has no gain knob... How to adjust?
  • 4
99redrado
Hey everyone I have a kenwood kac8104d amp that has no gain knob. The only thing it has that seems to control the power is a bass boost db knob. Is there any way to adjust the gain? Also what should the bass boost be set at? I have it at about 6, amp is powering 2 jl 300 watt 10 inch subs.
Several companies including PAC...Metra ect make a bass knob that can work inline between your deck RCAs and Amp RCAs
ive got three pac models i use for my home system between my p/c dsp and five/one. some of the most mundane yet necessary impliments ive used in this application for signal adjustment
Ive set them up as independent remote gains on each amp when doing old school SQ builds...on the mids and highs as well as subs to balance the system...
250
Check your remote line or RCA, some decks have written remote 2 times different wires one solid blue one blue and white, some do the misstake...
10
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
99redrado
99redrado
North Carolina
Louisiana_CRX
Decebal
    Jun 10, 2024
