Amp issue Need help
  • 2
SubFocus
I have a Exile 2400.1, and im currently transferring my system to another truck, I turn the key back to allow power and my deck and satellite radio will turn on but my amp wont. When i turn the key to the normal off position the light for the amp will turn on for a second then off again. Same thing happens when i start the truck, ill start it and it doesn't come on when i shut the truck off it will power on for a second then turn back off.. Am i missing something? any help would be greatful
Exile 2400.1
JL 10w7AE
2004 Ford F250
I discovered the problem, but im confused by it... The remote wire must be plugged in but why is that? without it, the amp only comes on with the FM/AM radio
170
I would do the same. Its possible its up under the dash or behind the glove box
14
Pull the amp out, bring it to the front of the vehicle, and connect it to the battery. Does it power up? Go from there.
7
Is the amplifier secure/bolted down or has it been moving around/just laid down in the vehicle not secure? I would check your wiring connections...
SubFocus
SubFocus
Chehalis,WA
mylows10
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
