Amp Ohm Question/Suggestions
  • 2
Peggle
G'morrow gents,
So I know some of you are tired of seeing me post a bunch of crap, but bear with my noobiness for just a little bit longer. So my Boss PH3000D is blown and I'm now tasked with finding another amp. I seriously don't want to fk up my next purchase so I'm back here asking more questions. //content.invisioncic.com/y282845/emoticons/redface.gif.62fdbfe1a101588a808c4cff71bcb942.gif Ok so down to the reason I'm here. I have 2 12 Rockford Fosgate P3d4 @ 600rms each and I've noticed something while looking at amps. All the amps have a rating such as
1200w rms @ 1 ohm
900w rms @ 2 ohms
600w rms @ 4 ohms
In the past I was trying to find an amp that does 1200w rms at 4 ohms but those amps run at $800-$1500 which is stupid expensive. Whenever I first started looking into a system I read that running your setup at 1 ohm generates a lot of heat thus shortening the life of the amp/subs which is why I was trying to find 1200w rms @ 4 ohms. Can someone enlighten me on what I'm missing? Would it hurt anything if I bought one of those amps that does 1200w rms @ 1 ohm?
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
It also lowers the amps efficiency and raises the current draw.
5
676
Thank you for your advice, everyone. I feel much more confident going forward. You guys are great (y)
17
Peggle
Peggle
Dallas, TX
basswiigee
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
