Amp power question.
  • 2
ForesterPete
Umm is this thing on?!?
Ok so I have a JL 1000/1 amp. Everything is hooked up correctly, double and triple checked it. Ok so here's the question. Should of any voltage be read at the +/- speaker terminals with the amp/ car shut off?
Right now I'm reading .038v at the speaker terminals with the amp off (power light is off). The reason I ask is because one day I came out to a dead battery in my forester. Now it was a very ****** battery one of the cheepies from Walmart but it was only 2 months old. I had the battery tested and it was still good, never the less I replaced it with a die hard gold battery and i also installed a 200a breaker so I could easily kill the main power to the amp. So back to the question should I be reading anything on the amp with the power off?!?
The way RIPs works
It stores power in caps to have it on hand when the voltage drops. You may be reading some bleed off. Test it again after it's been sitting for a while.
I don't think that's the reason for your issue.
If you do use speaker baffles.. I recommend the plastic ones rather than the foam ones, and drill a 1/4" hole at the bottom of it in the back for...
9
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
4
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
ForesterPete
ForesterPete
West coast
ForesterPete
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
