Help!! Need information on my amp, no idea what it is
  • 2
Dnknme
Hi new here to the forum, so this is my first post //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
I have an amp that I purchased in a lot of audio equipment a while ago. But I've never known the brand, model or actual rating of the amp. I once found the amp online but lost it.
I'm hoping someone has one of the same amps or has some knowledge about it as I'd love to know more about it.
Anyway I know it will put out 1500 watts with a 40herts tone on 12volts. It has a built in cooling fan. It's 2 channel and bridgeable. But if someone can help id really appreciate it.
Thanks in advance,
Dylan
Hi new here to the forum, so this is my first post //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gifI have an amp that I purchased in a lot of audio equipment a while ago. But I've never known the brand, model or actual rating of the amp. I once found the amp online but lost it.
Thanks in advance,
Dylan
If you can pull the bottom plate off and get a pic of the circuit board...Also on some circuit boards they are stamped to the model and brand ...
11
660
726
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
959
If you want 5 channels of amplification you just need 5 channels of amplification. You can do this with 5 amps or 1, depends on budget and space...
Dnknme
Dnknme
Greenwood, NS
Dnknme
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
