Amp power wire hook up.
  • 2
If you have multiple amps you do not need to run a power wire from each amp to battery..
You can have a single run of wire with a distribution block, it will then distribute a power wire to each amp.
Yes you want the fuse close to the battery.
EMR sniffer or AM/FM sniffer. small radio but with a probe antenna to it. It gives you the specific location on the ground loops. This device...
26
3K
Got it , LOC black wire actually needed to be grounded . Every video I watched said said it doesn’t and that’s just to reduce noise but apparently...
12
JohnPD
CarAudio.com Regular
JohnPD
Ravenna, Ohio
deez283
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
