Amp problem: Alpine 5 channel MRV-F357 cutting out and fuzzy
  • 2
Christo19
Rockfords are God.
I have this 5 channel amp doing some odd things. The battery is charged on the car and grounds are good, I have grounded the amp to the battery directly.
Problem is that when I hook up a speaker it will sound very fuzzy/distorted, also very quiet. Randomly it will sound a little better and kinda normal but then they will cut out and stop playing then continue randomly.
It feels like the amp is getting kinda hot too. I have a normal green power light, I have tired playing with the gains and all settings with no luck. I hooked up a different amp to the battery, rcas, remote and speaker and it worked. I tried different fuses also with no luck.
Any ideas on whats going on? I really want this amp to work and hope its not too messed up :/
thanks guys!
Is your battery to body ground good, going to shiny bare metal with a bolt and not a self-tapping screw? What voltage do you measure at the +12V terminal of the amp while music is playing?
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
853
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
759
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
Hello Everybody, Due to an incorrect install from a local stereo shop one the channels of my Alpine PDX-F4 is no longer working. I was told...
Christo19
Rockfords are God.
Christo19
Bozeman, MT
trumpet
