Amp Problem
  • 2
Dissconnect all speakers from the output. Power it up. If it goes into protect mode give it back to your buddy and get an amp that works.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
778
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
723
If a sub's voicecoil fails, it will usually drop impedance causing too much current to go back to the amplifier. The amplifier then protects...
15
Have you checked the fuse block. With time, tight connections can loosen and cause failure. Refresh those contact points and test again. Remember...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
138
baggedmazda
baggedmazda
Lincoln,NE
Bake
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
